Electronics => Projects, Designs, and Technical Stuff => Topic started by: Tony.T on May 20, 2024, 02:39:40 pm
Title: 100GEA 420FZ0S Component....
Post by: Tony.T on May 20, 2024, 02:39:40 pm
I got a mainbord for a LG TV.
This component above givs me a unstable pwr_on signal.  Something is wrong and i located the signal to this chip.
Anyone knowing what kind of chip it is? Some say voltage regulator? Some say it is i microcontroller.  I would guess the last one is right.??!!!!
That means that i can not replace it with another chip i have that sais 100GEA 728UZ03   ??      It needs to be programed first.
Can someone please confirm this?
I cant find proper information on the web regarding this chip  100GEA 420FZ0S
The chip looks like this one....but the markings is not the same...
https://www.aliexpress.com/item/4000251963110.html (https://www.aliexpress.com/item/4000251963110.html)
Title: Re: 100GEA 420FZ0S Component....
Post by: kundewayne on May 27, 2024, 03:59:57 am
That means that i can not replace it with another chip i have that sais 100GEA 728UZ03   ??      It needs to be programed first. basketball stars (https://basketball-starsgame.com/)
You're right to exercise caution when it comes to mainboard repairs for your LG TV.  We can analyze the following depending on your description:
The Issue:
The power-on signal on the mainboard of your LG TV is erratic.
You think there may be a problem with a certain chip (designated 100GEA 420FZ0S).
Problems:
It is challenging to determine the precise chip function—microcontroller or voltage regulator—without a schematic or service manual for your particular LG TV model.
Even if the chip is accurately identified, replacing it could be difficult.
Post by: Phoenix on May 28, 2024, 06:05:17 am
100GEA looks like a programmable gate array. Definitely need the correct configuration on it to work.
https://www.worldwayelec.com/pro/renesas-electronics-corporation/100gea/2758763 (https://www.worldwayelec.com/pro/renesas-electronics-corporation/100gea/2758763)
