I was running around the house with battery powered oscilloscope and small solar cell loaded with 1k resistor (BW tested to be sufficient for 1khz square wave)
Classic iron ballast 2x36W T8 fluorescent:
T5 2x54W electric ballast fluorescent:
Cheapo 10W E27 led bulb in kitchen:
T8 36W countertop fluorescent:
230v GU10 led spotlights in bedroom:
None of the lights flicker in my eyes but GU10 spots in bedroom are downright nasty otherwise. Any movement is really jerky. Even when reading a book and turning pages the movement jerks.
Bathroom GU10 led spotlights were bit worse than typical iron ballast 36W tube, motion in there is slightly jerky but not to the point of dizziness.
All of the E27 led bulbs currently in use had very low ripple.
Conclusion based on comprehensive one subject objective study: Keep the ripple amplitude below 30% and it should be "good enough"
