Well, search as I might, I've not run into a clock divider which seems suitable for a purpose I have in mind. What I want is a gadget to divide my GPS receiver's output (I have a choice of 100k, 1mhz, 5 mhz, 10mhz, etc) to 60.000hz. The purpose being to provide a clock signal to a free-running display which I have on my bench. Just for local time of day, nothing more important than that. Any suggestions here about a hardware solution which might be "plug in and go", or (second choice) perhaps a circuit which I could put together in an afternoon? I'm quite sure that there are software solutions, but that would probably be far more complex than I want to mess with. Ideas? Thanks, all, in advance.
Edit: Thank you all for your ideas and suggestions. Some I'd not considered.
So, let me correct my original statement slightly - the clock display is a single IC clock chip driven by the 60hz main supply here in the US, but does indeed drift as compared to my two GPS receivers. One is a TrueTime (which has the jumper selectable output clocks frequencies), and the other is a Trimble which I placed in a rackmount chassis also. I use these as master clocks for frequency counters, etc. Now, I've not actually checked carefully the apparent drift over a period of days, I just notice that it's off by several seconds to maybe a minute or so when I do check occasionally (every few days, or a week or so).
The real nuisance part of this story is that TrueTime makes a display which is driven from IRIG-B, which my TrueTime receiver outputs as well as the selectable 100k, 1m, clocks etc. I had one a few years before I purchased the TrueTime GPS receiver, but I sold it because I didn't think I'd ever use it.
So there is where I am, and it's just a matter of curiosity, not necessity that I would like a display on the bench that remains "on time", day to day.
So, again, thank you, and keep the ideas coming.
