Whoa, lots of replies.
It’s unusual, but have you considered PCB windings for the transformer secondary?
Usable up to ~20kV tops from my experience, and a bit of a mess to make, especially for higher power.
What you need in my opinion is a massive ferrite C core.
Doing exactly this - 20mm separation on either side, 40mm ID C-core.
As for the HV side sensing circuitry you can simply have an extra winding to create a supply voltage for it and treat the -100kV as being ground, this lets you use normal opamps up there to sense all those parameters you want. Tho i would recommend putting the elctronics in a shielded box that's also connected to -100kV to protect the circuitry from any potentially very strong fields drawn to anything grounded.
The high voltage PSU is very low power(calculated to be 8W
input), and the HV transformer itself is only good to ~15kV. The rest is going through a 5-stage CW multiplier. This is why I'm doing a separate -HV filament supply.
a toroidal transformer with a diameter of around 40cm
That is gigantic for my application - the entire system will probably be thinner than that, and definitely shorter.
Have you considered a BLDC motor driving another through a plastic rod?
That is a crutch even I won't consider, and I've done some pretty hacky stuff. Fairly easy to implement, but a bit nuts to add mechanical transmission of power. That, and you can't pot it.
That is going to be a mess, silicone is not free flowing so its not that easy to vacuum pot, especially with weirded shapes like transformers. Anyway why would you want to pot a research module like that, you will not be able to make repairs, change things or study potential problems.
I have some low viscosity 2-component HV silicone that will work great for potting. It's not going to be an extremely tight assembly, so penetration won't be an issue. I might also be potting
under vacuum, with air ingest to push it as far as possible.
This isn't a research module - I'm intending this as a part to go into an assembly that will sit inside an x-ray microtomograph. It will never be taken apart or serviced.
Oil is really messy to work with, and potting gives me standalone modules I can mount in air, rather than having to design and build enclosures and passthroughs for every cable. That, and as you've mentioned, it needs to be very dry, which is hard to achieve without using drying agents or buying brand new oil.
There is a Taiwanese company making up to 0.5W (recovered electrical power) per channel laser fiber power delivery systems.
Nope. The filament needs ~5.5W peak, + regulation losses.
I do have one question, though: how does the tube know what potential it's at?
It doesn't. You need a regulated HV power supply to get the x-ray energy you want. In my case it's a beryllium window tube, so anything from ~10kV and up will output x-rays, though 10keV won't do much other than photoionize surfaces.
How much do you have to pay for the modules and how much power do you get through?
Not a lot, and see above for power.
It’s totally out of scope, but now I’m imagining an X Ray tube that replaces the filament with fibre fed laser heating. After all, converting laser light to electricity to run a heater is very inefficient.
It could work - just have to set up a high vacuum glass-to-metal and beryllium window production line first. Quick, patent it!
Filaments burning out is a very large part of why X-ray tubes die in general, so if you eliminate that, they could last a very long time.
Designing a compact HV source with isolated filament supply is quite a weird combination, considering basically no modern microfocus x-ray tube uses a grounded anode setup, because as you can see, complications arise.
Grounding the anode lets you leave the focusing voltage regulation to the tube itself(via a resistor to the "grid"), but modern electronics have gotten good enough to generate the focusing voltages externally. Kevex tubes are a nice example of that - the tubes are ridiculously long and there's a whole braid of cables coming off the anode.
