Author Topic: 100uA LED current source ideas  (Read 590 times)
Offline hex4def6
« on: September 13, 2020, 10:36:40 pm »
Hi all,
I'm trying to keep an LED lit to a fair amount of accruacy at ~100uA. Right now, I'm just using a 5V rail, LED, and resistor. However, I'm concerned that there will be device to device brightness bariation doing this, due to variable Vf of the LEDs.
Does anyone have a good idea for a cheap / low part count solution? I'm mulling using a mosfet current mirror / Widlar current source, but I'm concerned that mosfet mismatch is going to be a problem doing this.
I don't need super accurate -- 10% variation is fine.
Suggestions?
Offline exmadscientist
Re: 100uA LED current source ideas
« Reply #1 on: September 13, 2020, 11:24:20 pm »
MOSFET (or better yet, BJT) current mirrors are great if you have a reference current available, but not so helpful if you don't. To get that reference current, the easiest way is usually to use a voltage reference. And since you don't need any great accuracy, you might as well use a cheap "adjustable" reference. A TL431 and a couple of resistors should be able to do exactly what you need. Just set up the LED in series with a sense resistor, and configure the '431 to regulate the IR drop across the sense resistor to your desired current. (You might find that you prefer one of the variants or alternatives with 1.24V feedback voltages.)
Online bdunham7
« Reply #2 on: September 13, 2020, 11:46:10 pm »
A 3.5 digit 4.5 digit 5 digit 5.5 digit 6.5 digit DMM is good enough for most people.
Offline S. Petrukhin
  • Country: ru
« Reply #3 on: September 14, 2020, 12:00:33 am »
I think the difference in Vf for LEDs of the same type is insignificant and will not greatly affect the brightness. However, if you use LEDs from different manufacturers and different types of the same manufacturer, the brightness will be very different even at constant current.
And sorry for my English.
Offline I wanted a rude username
  • ... but this username is also acceptable.
« Reply #4 on: September 20, 2020, 05:31:48 am »
This seems a ready-made solution:
Also the LM334 as a general solution.
Offline Someone
« Reply #5 on: September 20, 2020, 07:33:11 am »
Check your data sheets, very few LEDs are binned to that level of consistency.
Offline Zero999
  • 0999
« Reply #6 on: September 20, 2020, 08:27:13 am »
Even if you regulate the current perfectly, variations between LEDs will cause them to be slightly different brightnesses. Power = VI, so an LED with a higher forward voltage, might be slightly brighter, or have a shorter wavelength, thus be a different colour, than one with a lower forward voltage.
Offline daqq
  • Country: sk
    • My site
Online madires
  • A qualified hobbyist ;)
« Reply #8 on: September 20, 2020, 07:40:09 pm »
A 0.1mA CLD. ;)
  • Country: ru
« Reply #9 on: September 20, 2020, 07:47:57 pm »
A 0.1mA CLD. ;)
0.1 or  0.2 or 0.3 or 0.4  :-DMM
Offline Benta
« Reply #10 on: September 20, 2020, 09:43:56 pm »
Here you go:
