Electronics => Projects, Designs, and Technical Stuff => Topic started by: BurningTantalum on December 23, 2017, 12:13:18 pm
A non-technical friend called to say that he had acquired a box of "those things that you have in your workshop" and did I want it, so I told him to bring it round. It was a huge cardboard box full of electronic components, some in ziplock bags, some loose. It has taken me all afternoon to sort them into heaps on the dining table- anything with 3 legs in one heap, ICs in another heap, caps, diodes, connectors etc. I think that it came from an electronic supplier that closed down many years ago in a town down the coast. Many of the plastic bags have flaked to bits with UV exposure, so I grabbed handfuls of loose components and sorted them roughly.
One component (among many) caught my eye. It is a STR440 in a modified TO3 case (3 legs.). I cannot find any data on this, other than it is a monolithic 107V output 0.6A regulator.
I don't recall seeing anything that needed 107V specifically.
Any ideas for its intended use?
I have seen the 3 leg TO3 case style only once before, and it was a high-voltage switching transistor by Motorola used in a vehicle ignition system.
Regards, BT
STR440 is a high (107V) voltage regulator to supply the picture tube coil of a tv.
(http://www.dtforum.info/index.php?action=dlattach;topic=11158.0;attach=268582690;image)
Picture tube? Don't be silly, TVs don't have a picture tube and a coil, instead they have an LCD screen.
Oh, I think I remember that TVs a long time ago had a picture tube and deflection coils.
108 volts is also common in oscilloscopes which may have something to do with being twice 54 volts.
Sanken commonly made modules like this and judging by the part number it's one of those!
You did a funny!
Thanks everyone- I knew that someone would know!
Happy New Year, BT
What is this antique tech you call an LCD? Everybody knows TVs have OLEDs. ;)
