Been having a little trouble looking this one up since. All my searches just bring up topics about plugging 110 VAC devices/appliances into 220 VAC.
So the source voltage selector switch on my little Chinese SMPS. Would like to get an idea as to how exactly it works as it looks like it's tying the neutral between the filter caps on the DC side of the rectifier. I'm assuming the Caps act like a voltage divider for the 60hz 120VAC and this some how biases/bumps the DC side so the circuit thinks it has 220VAC. Not really sure but I drew up a circuit based on what I see and probing.
It doesn't help that i'm trying to repair the little guy since I fat probed it a while back. I was trying to get a measurement of VCC on the switching regulator IC and my DMM probe lipped and shorted VCC to OUT and blew open the whole switching circuit. I've replaced everything i've found to be blown: MOSFETs, BJTs, resistors, rectifier, and fuse. Then tested the remaining components in the switching circuit. I'm sure there's a good chance the IC is dead, but I'm hoping not.
