Author Topic: DIY Heart ECG wearable recorder (Holter monitor)  (Read 16004 times)
Offline Kaptein QKTopic starter
« on: September 16, 2013, 02:55:14 pm »
Experiencing strange sensations and feelings in my chest I did the only logical thing... Make a ECG recorder!  :)
I bought a front end from http://www.100randomtasks.com/ecg-front-end
and connected it to an Arduino Nano. (Don't worry, no Arduino IDE's where harmed in this project...)
The data is stored in a 16MB flash chip.
The PC part where written in C#, my first program in that newfangled thing called OOP.
See pictures and ZIP file for source code. If there is interest I can provide more details.
I was able to catch a few of those glitches, see picture. (Third line in the middle)
Now tell me...   How much time do I have?   :D
Offline mmagin
Re: DIY Heart ECG wearable recorder (Holter monitor)
« Reply #1 on: September 16, 2013, 03:04:24 pm »
While this kind of configuration seems to work fine for the simple heart-rate monitors used when people are working out, I seem to recall that most ECG setups (even simple ones) use some kind of driven guard electrode attached elsewhere on the torso.
« Reply #2 on: September 17, 2013, 10:31:14 am »
The ECG front end has resistors from each lead to Vref to keep the common input voltage in range for the input amplifier.
« Reply #3 on: September 17, 2013, 10:33:25 am »
Looking at the ECG waveform I'd say 15 months, at most!
Hey, that is not to bad, I get to see another summer!  :)
Offline saturation
  • Doveryai, no proveryai
    • NIST
« Reply #4 on: September 18, 2013, 07:26:51 pm »
That strange 'blip' above the red line is a premature ventricular contraction.
http://en.wikipedia.org/wiki/Premature_ventricular_contraction
Best Wishes,
 Saturation
Offline mmagin
« Reply #5 on: September 18, 2013, 09:26:27 pm »
That might be enough, I'm not experienced enough to be sure -- I was thinking the movement of the leads and amplifier relative to the patient could cause enough interference in the signal to be a problem, maybe.  I've only done this once long ago in a college class with an instrumentation amplifier and a commercial A/D board.  I think we had a third electrode on the torso which was driven by the amplifier output or something.  Possibly this was more essential when the amplifier wasn't mounted right on the subject :)
Offline Chryseus
    • My Website
« Reply #6 on: September 19, 2013, 12:17:06 am »
I see nothing wrong besides a PAC followed by a PVC on the second line which is nothing to be concerned about, first and third line is due to noise from movement or the leads making poor connection.
Offline Psi
« Reply #7 on: September 19, 2013, 02:13:23 am »
You should put a bright LED matrix on the box, so at night you actually see your realtime ECG waveform through your tshirt :)
hehe, electrolumenesent array t-shirt that shows realtime ECG
Now that's a good idea for a kickstarter.
Actually i think a flex PCB with bright SMT leds would be better. Best to make it not part of the tshirt at all.
Just have a internal pocket behind the chest where the flex board sits.
« Last Edit: September 19, 2013, 02:20:05 am by Psi »
Offline Psi
« Reply #8 on: September 19, 2013, 02:24:05 am »
Id like to see your doctors face when you show up with your own home built ECG readout of the issue.
« Reply #9 on: September 20, 2013, 01:22:06 pm »
Thanks!
« Reply #10 on: September 20, 2013, 01:30:08 pm »
Thanks!  The noise is due to movement.
The incident which made me make this device was much longer (minutes), but I did not have other symptoms. It only happened a few times during a hour.
So I guess I will see several summers come and go! :)
« Reply #11 on: September 20, 2013, 01:35:18 pm »
Haha, good idea! Imagine a date: "Your BPM is rising. Are you getting horny?"   ;D
« Reply #12 on: September 20, 2013, 01:39:52 pm »
Unfortunately I do not have recording of the issue which made me make this device. Since there where no other symptoms I will let the doctor wait.
Offline Psi
« Reply #13 on: September 23, 2013, 09:23:57 am »
You have the screen capture of it.
