Author Topic: Precision Low-Voltage Function Generator  (Read 2553 times)
Offline jram112Topic starter
« on: September 23, 2013, 08:32:49 am »
I'm wanting to create a precision low-voltage function generator with isolated power supply. I only need sine and square waves with amplitudes between 10uV - 1V and frequency range between 0.1Hz-10kHz. This device will be used to calibrate biomedical hardware. It will also include differential and single ended outputs.
This device is very similar to what I need, but is almost 600 USD: http://www.ecgsimulators.com/products/model-220-function-generator. I think I'd rather create one and share the design with everyone. However, I have aquired one of these for $75 and will be performing a Dave Jones' inspired tear down with my screwdriver and camera...."take it apart". :)
My initial thoughts are to use a DDS chip like Analog Device's AD9800 series DDS >> then condition the signal with a LPF >> then use a precision single-chip voltage divider network to get lower voltages >> finally followed with a precision auto-zeroing opamps for buffering. Amplitudes will be controlled by the DDS chip output.
This may be a horrible initial design, but that's why I need input from you guys. How would you guys design such a device?
« Last Edit: September 23, 2013, 08:48:18 am by jram112 »
Offline fcb
    • Electron Plus
Re: Precision Low-Voltage Function Generator
« Reply #1 on: September 23, 2013, 08:58:38 am »
Use an audio DAC.
Offline dannyf
« Reply #2 on: September 23, 2013, 10:01:52 am »
Up until the opamp part, that's what those $5 ebay DDS modules do.
The stock ebay dds module allows amplitude modulation via a small change, but probably not at your resolution / precision. A better approach would be to use an outboard pga. The 10uv-1v range is actually pretty wide and you may want to look into an analog pga rather than a digital one.
