J4 is the output, it's connected to a switch and that will connect the output banana plugs to the source or a 1K resistor to discharge the test capacitor.
J2 is a transformer with 12 taps with different voltages from 8V to 350V that can output 250mA max. I'm switching between the taps with a selector.
The MCU acts as a meter, measuring and displaying output voltage and current, plus a few more functions.
If the output current range set to 1mA it's perfectly safe, but at 100mA range it definitely have a nasty shock.
The floating ground is limiting the current, there's no limit on the actual ground...
I posted a link to the images of the device, the transformer is visible there.
