As a part of a larger project I'm developing a load cell front-end, the first circuit I've prototyped is the one attached where I have the ADC connected to I2C to an arduino uno taking the measurements, the signal from the load cell is at 10mV and has to be amplified to meet the ADC's (ADS1115) full scale input range, so I used an istrumentation amplifier (AD8236) with suitably selected precision gain setting resistor.
The problem I'm having is a gross gain error, so basically the amplifier gain is only 7 instead of 25 as it should be; the theories i'm coming up with are as follows:
1) even though the in-amp is marked on the datasheet as Rail-to-Rail input and output has some limitation in input and output so it cant gain so much with reference voltage grounded
2) since the prototype board is through hole (Inamp and ADC are SMD on breakout-boards) wired point to point with 30 AWG wire wrapping wire and the wire (not more than 10 cm) between sensor ground and inamp reference-ground (which are soldered toghether really close) is enough to cause gain accuracy issues as stated in the datasheet
3)something else I haven't thought off
so what do you think is the issue here?
UPDATE 1: I need a gain of 25 to get from the 10 mV FS of the load cell to the 256 mV FS off the ADC
If the first is the likely culprit my solution to that would be lift the reference pin to mid supply and use the ADC as differential bethween vref and vout of In-amp, can it work or i need a fully differential amp and have a real differential front-end
