Author Topic: A Quick I2C Question  (Read 1969 times)
Offline German_EETopic starter
« on: November 26, 2015, 07:14:58 pm »
A question for those who know more about I2C than me. Assuming a 100 KHz interface speed how many I2C writes can I do per millisecond? The receiving device is a memory chip so the limitation here is the bus speed.
Warren Buffett
Offline 0xdeadbeef
Re: A Quick I2C Question
« Reply #1 on: November 26, 2015, 07:27:39 pm »
This also depends on the device. Reading from or writing to the "current" address is faster than a random access. But continued read/write is typically limited by the actual device (EEPROMs tend to have "pages" e.g of 64 bytes).
Full random write access:
START | 7BIT_DEV_ADR | 0(Write) | ACK(Slave) | 8BIT_ADR_HI | ACK(Slave) | 8BIT_ADR_LOW | ACK(Slave) [ 8BIT_DATA | ACK(Slave) ]xN | STOP
Current address read:
START | 7BIT_DEV_ADR | 1(Read) | ACK(Slave) | [ 8BIT_DATA | ACK(Master) ]xN | 8BIT_DATA | NACK(Master) | STOP
If you count START, STOP and ACK/NACK as one clock, you can calculate with the above information how much clocks you need to transfer N bytes of data.
Offline Fungus
« Reply #2 on: November 26, 2015, 08:01:42 pm »
To send one byte of data needs 9 clock cycles, so your maximum speed is slightly more than 11000 bytes/sec.
But you also have to send extra data because you need to address the chip, set up the writing address, etc. The amount of extra data will depend on the memory chip.
« Reply #3 on: November 26, 2015, 08:25:47 pm »
I think I'm going to make it. The requirement is to send 8 writes in 5 milliseconds and the figures from Fungus indicate about 55 possible writes in the same period less address overhead
Warren Buffett
Offline dannyf
« Reply #4 on: November 26, 2015, 08:34:47 pm »
100Kbps/9 bits per byte transmitted * 1ms = ?
« Reply #5 on: November 26, 2015, 08:37:30 pm »
That's the theory Dannyf, but with I2C there is a lot of overhead with start bits, stop bits, ACK signals and lots of other stuff. Hence my question.
Warren Buffett
Offline Fungus
« Reply #6 on: November 27, 2015, 07:27:34 am »
Should work even if each write is 4 bytes total.
(ie. I2C address, 16-bit chip-memory address, data byte)
