Wow…
If you read my post you would know that…
It’s a Gyroplane, a RAF2000, home built, non certified,
I work in an aircraft maintenance hangar, I have already asked local avionics people and it’s get a glass cockpit answer..
It does not void insurance
I am just looking for a circuit to do
12vdc to 400 hz single phase at 115v at an amp out
1. Well, RamJet, I DID read your post(s) and I didn't see any reference to the type of aircraft that you now say is a Gyro-copter RAF2000 which, by the way has a checkered record from its development in South Africa to its lawsuits because of pilot deaths in the USA. so, Good Luck with that! I decided long ago that I wouldn't fly anything that didn't have WINGS so it could glide, not plummet.
2. The glass cockpit is the RIGHT answer for your build of the kit-copter.: Modern, lightweight, low current draw, portability, multi-instrument display, GPS map, low cost, etc., etc. so, maybe pay a little more heed to the avionics folks, huh?
3. I'm sorry that I cannot recommend or furnish you with an inverter circuit diagram that you could build or have built for you because it would eventually be going airborne and, you can say I'm spoiled rotten, but I'm a stickler for FAA-approval and compliance to approved and type-certificated products and processes even in the home-built and experimental categories and any circuit that I could provide would not meet those safety standards.
I wish you the best regards in your flying endeavors, nevertheless. I'll close with my old quote for fellow pilots: "Remember, you can't pull over to the side of the road at 5,000 feet to fix a problem. Do it before takeoff!"
Best,
Major.
