Check your frequency response. Sounds like unbuffered is better and you certainly have the drive for it.
what is that a graph of? the reference or the DAC?
What is this?20 V peak to peak
Quote from: Arjunan M R on May 30, 2019, 06:32:19 amQuote from: Simon on May 30, 2019, 06:30:38 amYour link is brocken, but what you do is look at the output current of the voltage reference in it's datasheet and then look up the input current to the voltage reference pin in the datasheet for the DAC.No it is working.When you click on it it will automatically download the pdf fileNo it was brocken and you just edited it! If that is your attitude good luck learninig electronics. Maybe you want to try lego bricks where everything is made for each other and nothing can go wrong!
Your reference outputs 10mA, I doubt any DAC input wants moro than that. read carefully any notes about the output capacitor value and type required.
Yes just follow the datasheets recomendations. You are drawing µA not mA so you don't need to go heavy handed on the output capacitance. Filtering it is not a bad idea.
