Hey folks. I have 15 pieces of 15 ft RGBW LED strings that I want to install for ambient lighting in a new home theatre build. Studs are exposed, so I can get creative with wiring.
Here's my dilemma. I want to avoid running standard AWG 14 house wire (romex) with 110V AC to each string as then I'll need junction boxes, etc. I'd much prefer to run a wire through the drywall through a small hole. This way, in case I sell the house, the next owner doesn't need to patch 15x holes in the wall from junction boxes. So I'm stuck with a low voltage solution (<50V).
My first through was to use 5-conductor AWG 18 "thermostat" wiring from a centralized controller to each LED string. Thermostat wire is rated class 2, so it can be concealed behind walls. Then I could use one wire as +12V common anode, and then the other four as cathodes for each of the RGBW lines. The strings will be up to 40ft away from the controller, and will draw 2-4A, so I'm concerned about the voltage drop as well as EMI from PWM over long distances.
Another idea is to send +12V and GND over two wires, then some communication signal over the others. Then a receiving controller could PWM the string locally. The problem is that the thermostat wire doesn't have twisted pair, and I'll still have the voltage drop issue and possible EMI that back-propagates onto the power/ground wires as well.
The last idea is to use 2-conductor thermostat wire to send a low-voltage AC to each string, then either use WiFi/separate CAT5 for communication.
What would you do in my situation?
