I am looking for inputs to select a low noise +-15V isolated DC-DC converter module, for a low noise <1MHz analogue circuit
isolations i needed to break ground loops/avoid them.
Requirements:
Input voltage: 5V ( but others voltage can do as i have not settle on the main PSU)
PCB mounted
1Watt will do
Isolating 500V is ok
Low EMI as i will have near by connectors and PCB's i want to avoid coupling to
if LDO output not included a good candidate for that is also highly well-come - I prefer my output voltage being +-15V but my circuit will work down to +-12V
thanks
already had a look on Traco and found this one
https://docs.rs-online.com/8145/0900766b816ed6f1.pdf with low noise
but its kind of expensive! and i do not need that much current
i may consider taking a cheaper one and add an LDO but there is still the emi but may be just fine with a good EN 55032 rating
already had a look on Traco and found this one https://docs.rs-online.com/8145/0900766b816ed6f1.pdf with low noise
That is the price you pay for taking modular power solution shortcuts. Little PCB mount switcher modules tend to usually be significantly more expensive than making your own application specific optimized solution.
Also careful with common mode noise on isolated switcher modules like this. The sharp switching edges love to jump across parasitic capacitance of transformers (switcher modules have to contend with this too as they contain the same transformers inside).
