@oPossum
I have tried your (first) example and copied the boolean expressions and it works fine.
I think my initial CUPL code was too 'abstract' for the compiler to optimize well...
This code:
Name 2-Digit 7-Segment Decoder;
PartNo 2D7SDecoder-01;
Date 18-12-2019;
Revision 01;
Designer Marc Jacobi;
Company Canned Bytes;
Assembly unknown;
Location unknown;
Device g22v10;
/*Format j ;*/
/** input pins **/
PIN 1 = CLK;
PIN 2 = D0;
PIN 3 = D1;
PIN 4 = D2;
PIN 5 = D3;
PIN 6 = D4;
PIN 7 = D5;
PIN 8 = D6;
PIN 9 = D7;
/** output pins **/
PIN 14 = a;
PIN 15 = b;
PIN 16 = c;
PIN 17 = d;
PIN 18 = e;
PIN 19 = f;
PIN 20 = g;
PIN 21 = dp;
PIN 22 = n1;
PIN 23 = n2;
/* not used */
n1.ar = 'b'0;
n1.sp = 'b'0;
n1.d = !n1;
n2 = !n1;
dec0 = (D0 & n1) # (D4 & !n1);
dec1 = (D1 & n1) # (D5 & !n1);
dec2 = (D2 & n1) # (D6 & !n1);
dec3 = (D3 & n1) # (D7 & !n1);
FIELD decode = [dec3, dec2, dec1, dec0];
FIELD output = [dp, g, f, e, d, c, b, a];
TABLE decode => output
0 => 'b'00111111;
1 => 'b'00000110;
2 => 'b'01011011;
3 => 'b'01001111;
4 => 'b'01100110;
5 => 'b'01101101;
6 => 'b'01111101;
7 => 'b'00000111;
8 => 'b'01111111;
9 => 'b'01101111;
A => 'b'11110111;
B => 'b'11111100;
C => 'b'10111001;
D => 'b'11011110;
E => 'b'11111011;
F => 'b'11110001;
resulted in these equations
a =>
D4 & D5 & D6 & D7 & !n1
# !D4 & D7 & !n1
# D0 & D1 & D2 & D3 & n1
# !D0 & D3 & n1
# !D0 & !D2 & !D3 & n1
# !D4 & !D6 & !D7 & !n1
# D0 & D1 & !D3 & n1
# D4 & D5 & !D7 & !n1
# !D0 & D1 & D2 & !D3 & n1
# D0 & !D1 & D2 & !D3 & n1
# !D4 & D5 & D6 & !D7 & !n1
# D4 & !D5 & D6 & !D7 & !n1
# !D1 & !D2 & D3 & n1
# !D5 & !D6 & D7 & !n1
b =>
!D4 & D5 & D7 & !n1
# !D0 & D1 & D3 & n1
# !D0 & !D1 & !D3 & n1
# !D2 & !D3 & n1
# !D4 & !D5 & !D7 & !n1
# !D6 & !D7 & !n1
# D0 & !D1 & D2 & D3 & n1
# D4 & !D5 & D6 & D7 & !n1
c =>
!D4 & D5 & !D6 & D7 & !n1
# !D0 & D1 & !D2 & D3 & n1
# D0 & D1 & !D2 & n1
# !D1 & !D3 & n1
# D4 & D5 & !D6 & !n1
# !D5 & !D6 & !D7 & !n1
# !D4 & !D5 & D6 & !D7 & !n1
d =>
!D4 & D5 & D6 & D7 & !n1
# !D0 & D1 & D2 & D3 & n1
# !D0 & !D1 & D2 & D3 & n1
# !D4 & !D5 & D6 & D7 & !n1
dec0 =>
D0 & n1
# D4 & !n1
dec1 =>
D1 & n1
# D5 & !n1
dec2 =>
D2 & n1
# D6 & !n1
dec3 =>
D3 & n1
# D7 & !n1
decode =>
dec3 , dec2 , dec1 , dec0
dp =>
D5 & D7 & !n1
# D1 & D3 & n1
e =>
D5 & D7 & !n1
# !D4 & D7 & !n1
# D1 & D3 & n1
# !D0 & D3 & n1
f =>
D5 & D7 & !n1
# !D4 & D7 & !n1
# D1 & D3 & n1
# !D0 & D3 & n1
g =>
D5 & D7 & !n1
# !D4 & D5 & !D6 & !D7 & !n1
# D1 & D3 & n1
# !D0 & !D1 & D2 & !D3 & n1
# D1 & !D2 & !D3 & n1
n1.d =>
D5 & D7 & !n1
# !D6 & !D7 & !n1
n1.ar =>
0
n1.sp =>
0
n2 =>
D5 & D7 & !n1
# !D6 & !D7 & !n1
output =>
dp , g , f , e , d , c , b , a
Have not taken the time to analyze what went wrong here...
