Author Topic: 17670 NI-MH Batteries  (Read 934 times)
Offline Nikos A.Topic starter
  • Country: cy
« on: July 15, 2019, 12:01:01 pm »
Hi everyone,
I unpacked a 17670 NI-MH battery pack from an electronic device. As you can see from the picture attached there is a series component (with red leads and something like a black bulb) on the negative side.
What is this component and what its purpose? Furthermore why there are two paraller negative cables?
Thanks in advance
Offline capt bullshot
Re: 17670 NI-MH Batteries
« Reply #1 on: July 15, 2019, 12:13:47 pm »
That component most probably is some kind of a thermistor, so the charger can stop charging if the temperature of the battery is too high or too low.
Paralleled wires increase the current capability (by lowering the resistance), this is the most common reason for having paralleled wires.
  • Country: cy
« Reply #2 on: July 15, 2019, 12:25:55 pm »
Thank you for your promt reply,
Is there any reason that places in paraller negative side instead of positive?
« Reply #3 on: July 15, 2019, 01:06:10 pm »
Normally, one would use parallel wires on both sides if one wanted to increase the current capability.
Here, it just might be done to compensate for the longer run of the black wire in comparison to the red one. But you'll never know without knowing the complete design or asking the original designer.
The following users thanked this post: Nikos A.
Offline Psi
« Reply #4 on: July 15, 2019, 01:12:11 pm »
Sometimes you also see a thermal fuse.
Offline mikerj
« Reply #5 on: July 15, 2019, 02:53:30 pm »
The additionally ground wire is likely to prevent battery charge/discharge current causing errors with the thermistor measurement, effectively a Kelvin connection.
  • Country: cy
« Reply #6 on: July 15, 2019, 08:03:30 pm »
Thank you guys!!
You are right, after searching I found that this is actually a 3 wire RTD (Resistance Temperature Detector) configuration. Actually it doesn't matter which one is the double wire (negative or positive). The key point is to maintain equal lenght in order to achieve equal resistance among the wires.
This site was helpfull
https://www.omega.com/en-us/resources/rtd-2-3-4-wire-connections
« Last Edit: July 15, 2019, 08:23:16 pm by Nikos A. »
