I'm looking to make a battery pack for a vintage computer (Epson PX-8) and it looks like after checking out the schematic, they don't seem to have any sort of voltage regulator on the battery, but seem to count on 4 cells of NiCD to give a valid range. Feeding 5.4V from my bench supply into the battery connector and I checked the voltage on a port on the back and it was coming up 4.95V, so I think they have something that is reducing it a bit. If I drop the 5.4V to 5.3, 5.2, the VCC goes down in .1V steps too, so it is following the battery voltage. So my concern is could the higher maximum or fully charged voltage of the NiMH be too much for it? How much higher is it than NiCD?
Here i the technical manual for it:
http://www.vintagecomputer.net/fjkraan/comp/px8/doc/px8-tech-manual.ch2.pdfPage 2-4 starts the power area, but 2-13 says when fully charged "5.4V" and low voltage 4.5V to 4.8V.
I've got some NiMH batteries - should I try to make a pack out of them? Or should I stick to NiCD?
