Author Topic: Find highest value of 4 inputs without microcontroller?  (Read 7481 times)
Online T3sl4co1l
    • Seven Transistor Labs
Re: Find highest value of 4 inputs without microcontroller?
« Reply #50 on: November 19, 2018, 09:21:59 pm »
Yeah, in the typical case, the pin connects to a sampling capacitor.  The RC time constant plus leakage sets the maximum value for meeting all specifications.  The actual leakage current is small, so the resistance is almost entirely just to ensure analog bandwidth comparable to the maximum sample rate.
Seven Transistor Labs, LLC
The following users thanked this post: spec
Offline not1xor1
« Reply #51 on: November 20, 2018, 01:18:52 pm »
just for fun (would need low tolerance or selected parts)
« Last Edit: November 20, 2018, 01:23:05 pm by not1xor1 »
Online T3sl4co1l
« Reply #52 on: November 20, 2018, 05:13:03 pm »
^ ;D
A perfectly fine application of the TL431, knowing that it is, in fact, an op-amp with a shortage of pins, an open-collector output, and a disturbingly large yet conspicuously stable (2.50V) input offset voltage. :)
Would also need the high side level translation, and would benefit from a low side CCS, but technically uses fewer pins than the LM324. :)
Online NiHaoMike
    • Facebook Page
« Reply #53 on: November 21, 2018, 01:57:31 am »
There have been contests around the 555, maybe it's time to have one for the TL431?
Online T3sl4co1l
« Reply #54 on: November 21, 2018, 02:05:02 am »
Sure. ;D
I want to see one around the UC384x.  I propose that it is as universal, or even more versatile than the 555.
The following users thanked this post: NiHaoMike
Offline not1xor1
« Reply #55 on: November 21, 2018, 05:27:14 am »
^ ;D
Probably the LM385-adj would work as well, with ground referenced output and finding the lowest output.
