Author Topic: 1986 Transistor Curve tracer - worth while building??  (Read 3320 times)
Offline wwjd1924Topic starter
« on: March 29, 2022, 02:21:21 pm »
I came across this video of the German ELV KS 7000 curve tracer.
https://youtu.be/isYHoyeXvk8
I think it's still a good design and relatively easy to build because it uses no special components except for the transformer but that can be solved.
BUT the text in in German which is no problem for me but I wondered if anyone is interested in English text?  I started the OCR/edit/translation process but as it's a bit of work I want to ask here first...  It's required though that people buy the original text from ELV for 1 euro.
https://de.elv.com/elv-serie-7000-kennlinienschreiber-ks-7000-teil-12-204310
https://de.elv.com/elv-serie-7000-kennlinienschreiber-ks-7000-teil-22-204319
« Last Edit: March 29, 2022, 02:25:16 pm by wwjd1924 »
The following users thanked this post: croma641
Offline Conrad Hoffman
    • The Messy Basement
Re: 1986 Transistor Curve tracer - worth while building??
« Reply #1 on: March 29, 2022, 04:26:58 pm »
Don't know about that one, but Heathkit made something similar way back that you might consider. https://elektrotanya.com/heathkit_it-1121_0-40v,1a_or200v,200ma_semiconductor_curve_tracer_1973_sch.pdf/download.html
Offline austfox
« Reply #2 on: March 30, 2022, 12:34:26 pm »
And Silicon Chip did a project in Oct '99 based on a design from Popular Electronics:
https://www.siliconchip.com.au/Issue/1999/October/Semiconductor+Curve+Tracer
Offline RichardM
« Reply #3 on: March 31, 2022, 12:38:28 pm »
I am interested in a translation. I purchased the German PDF articles and tried to simulate the circuit in LTSpice with no luck.
Richard
Offline jonpaul
« Reply #4 on: March 31, 2022, 01:39:13 pm »
Curved  tracers depending upon the max V, I W of the DUT.
We use Tektronix 575, 576 or 577 the best. Also a TM500 plugins CT501.
See old Heathkit, and other 1960s..1970s kits and construction articles
Jon
Jean-Paul  the Internet Dinosaur
The following users thanked this post: pardo-bsso
Offline PaulAm
« Reply #5 on: March 31, 2022, 03:28:43 pm »
Here's a pretty nice article on somebody building a curve tracer.  He has all the files available on github (links in the article).
https://www.paulvdiyblogs.net/2017/12/building-curve-tracer.html
Offline ledtester
« Reply #6 on: March 31, 2022, 03:52:47 pm »
Here's a review of the KS7000. You can skip to 38:15 for the reviewer's conclusion:
Curve Tracer Shootout-DCA75 Pro, ELV KS700, Circuit-ED CT100 -- KainkaLabs
The reviewer likes the KS7000 the best especially because of the voltage and current ranges it supports.
« Reply #7 on: January 22, 2023, 06:58:24 pm »
For the record...  I won't translate the text because of time... sorry about that!
Offline gjames50
« Reply #8 on: March 14, 2024, 09:01:11 pm »
I wish this kit was still available. I would love a unit like this. Paul's DIY made an updated version, but the overall cost to build his is just under 1,000.00 USD. Would building the ELV KS7000 cost less? Paul's DIY version has many nice features and improvements but the entry cost is a bit high for my budget.
I've spent a bunch of time converting this from German to English and I am sharing it here. I don't speak/read German, so I'm sure there are some grammatical errors, but I tried getting the technical stuff as correct as possible.
If someone who speaks/reads German/English could review this or perhaps edit it to make it more accurate, I would appreciate it. If anyone wants to help, please let me know, and I can share the Source Files that you can edit.
Enjoy!
Thank you!
The following users thanked this post: JeanF, ledtester, Grandchuck
Online Grandchuck
« Reply #9 on: March 14, 2024, 09:24:33 pm »
I think there is a market for a modest curve tracer.  I am thinking several hundred dollars.  The Peak Atlas is good but very limited.  It would be nice if it would utilize the typical 3 channel  DC power supply that most hobby/serious users already own.  USB port for image display on a PC?
Offline Messtechniker
Agilent 34465A, Siglent SDG 2042X, Hameg HMO1022, R&S HMC 8043, Peaktech 2025A, Voltcraft VC 940, M-Audio Audiophile 192, R&S Psophometer UPGR, 3 Transistor Testers, DL4JAL Transistor Curve Tracer, UT622E LCR meter
