Hey,
I've built a single-ended active oscilloscope probe to analyse one of my other projects (an active quenched single-photon APD which will get its own post at some point), and it's turned out pretty well. I'm considering setting up shop and flogging it on Ebay. It would be really cool to get some feedback and comments! Hopefully I'm not totally barking up the wrong tree.
SpecificationBandwidth (-3dB): DC - 1.15GHz
Probe capacitance: <1pF
Input impedance: 1MOhm
Output impedance: 50Ohm
Attenuation: 20:1 into 50Ohm, 10:1 into 1MOhm
Rise time: 500ps measured on my 500MHz oscilloscope. It's probably faster than this.
Measurable voltage range: +/-15V
Absolute maximum input voltage: +/- 50V
(simplified schematic for now)
This device is based on an OPA858 high speed FET input OP-AMP. I have it powered with a 9V battery, and have also a low voltage indicator LED. The probes are swappable gold plated pins, so you can have either sprung-loaded pins, rigid pins, flexible wires, or even a soldered connection to the DUT.
(data points >100kHz measured on a nanoVNA, low frequency data points added manually by checking amplitude response on an oscilloscope)
100MHz square wave.
(captured on my Agilent 54111D 500MHz oscilloscope, square wave generated by nanoVNA)
Here the white trace is the signal directly measured by the oscilloscope, and the red trace is the probe measuring the same signal
I'm going to look into a nice enclosure next. I'm working to keep the cost down of the unit, but it'll probably end up costing around £140 as I don't think I'll get much volume of sales which just makes everything more expensive. And I have to calibrate every device myself. So the probe is quite expensive, but still vastly cheaper than any other active probes out there. And actually much cheaper than any GHz passive probes also.
Some specific questions:
Would it be preferable to sacrifice a bit of bandwidth to reduce the peaking at 800MHz? It's only 1dB but maybe that's too much? Although it could be fakery caused by the nanoVNA too!!
Would my test results on my nanoVNA be accurate enough for someone to buy this? The device is calibrated but it's obviously not a professional piece of equipment.
Thanks
