I have a DS of CS8683 but only in Chinese. It is in PDF but idiograms are images cannot be translated by Google. Luckily they wrote in English (Float) that I can guess the lower the resistor to the ground, lower is the frequency, after which I suppose shorting it, is 300Khz. Before I plug it can someone confirm my guess? Thanks
