Author Topic: Breadboard Jumper Wire Red & Black  (Read 1051 times)
Offline PerranOakTopic starter
« on: August 16, 2019, 04:27:27 pm »
Does anyone know where to get a load of jumper wires (male-to-male) that are only red and only black?
I have loads of colours but 90% of the time I'm in a "positive/negative" situation where these two colours are best.
I've seen individual ones (20p each :-DD) but, obviously, want them at a sensible price.
Cheers.
You can release yourself but the only way to go is down!
RJD
Online tooki
Re: Breadboard Jumper Wire Red & Black
« Reply #1 on: August 16, 2019, 04:48:15 pm »
eBay. I've seen bundles of single color/length before.
Offline fourfathom
« Reply #2 on: August 16, 2019, 04:48:50 pm »
I bought rolls of red and black-insulated #22 solid wire for just this purpose.  I cut the wires to size, and when I'm done I throw them in a little box for later use.
We'll search out every place a sick, twisted, solitary misfit might run to! -- I'll start with Radio Shack.
« Reply #3 on: August 17, 2019, 02:23:57 pm »
Cheers but when you push them into the breadboard doesn't the insulation just move and cover the end?
The ones I have now have "proper" termination.
RJD
Offline Shock
« Reply #4 on: August 17, 2019, 02:37:34 pm »
Won't do that with a bend in it or if you pinch while inserting. If you were making a ton of them you could always crimp your own wires.
« Last Edit: August 17, 2019, 05:41:54 pm by Shock »
Offline fourfathom
« Reply #5 on: August 17, 2019, 04:36:35 pm »
It's just a matter of technique.
« Reply #6 on: August 17, 2019, 05:19:35 pm »
Crimp?
RJD
Offline Shock
« Reply #7 on: August 17, 2019, 05:47:43 pm »
Crimp?
Use a crimping tool to attach connectors.
« Reply #8 on: August 18, 2019, 03:09:16 pm »
Ah, interesting, cheers.
RJD
