Welcome,
Guest
. Please
login
or
register
Did you miss your
activation email
1 Hour
1 Day
1 Week
1 Month
Forever
This topic
This board
Entire forum
Google
Bing
Home
Help
Search
About us
Links
Login
Register
Electronics
Projects, Designs, and Technical Stuff
DIY STM32 flash programmer with FT232R
« previous
next »
Print
Search
Pages: [
1
Go Down
Author
Topic: DIY STM32 flash programmer with FT232R (Read 2602 times)
Boscoe
Frequent Contributor
on:
September 08, 2015, 11:25:31 am »
So i'm doing a programmer to make a batch of MCUs a bit easier to program with an automated process (program). However I'm having trouble with the UART comms. I have set all the baud rates etc. to the correct values and i'm sending the commands described in the boot loader documentation from ST but I get strange or no no response. First off the baud rate the boot loader is sending seems to be faster than the max of 115200 and some times I get one, two or three bytes sent back from the boot loader when I should be getting fifteen for the command I'm sending.
This is the document I've been using
http://www.st.com/web/en/resource/technical/document/application_note/CD00264342.pdf
If anyone who has experience doing this could give me some pointers?
Thanks
Logged
Psi
Super Contributor
Country:
Re: DIY STM32 flash programmer with FT232R
Reply #1 on:
September 08, 2015, 11:28:59 am »
I use this linux stm32 flashing tool to program some STM32F1 chips and it works fine.
http://sourceforge.net/projects/stm32flash/
You could look at the code or datalog what it sends and compare that to your app. It might give you some clues.
Logged
Boscoe
Reply #2 on:
September 08, 2015, 03:23:01 pm »
Thanks. I found what it was. I didn't initialise the boot loader, i just started writing commands to it.
Logged
Print
Search
Pages: [
1
Go Up
« previous
next »
Electronics
Thanking...
EEVblog Main Site
EEVblog on Youtube
EEVblog on Twitter
EEVblog on Facebook
EEVblog on Odysee
