Author Topic: Adjustable Step up regulator  (Read 1170 times)
Offline Aodhan145Topic starter
« on: May 09, 2015, 09:24:06 am »
Hi, I found this 150W Step up converter on Aliexpress, Would anybody be able to look it over to see if it is going to explode?
 http://www.aliexpress.com/item/150W-DC-DC-Boost-Converter-10-32V-to-12-35V-6A-Step-Up-Voltage-Charger-Power/32260792513.html
Thanks in advance.
Offline kjs
Re: Adjustable Step up regulator
« Reply #1 on: May 09, 2015, 09:47:17 am »
with just the 3 pictures it's impossible to judge anything. However, at an efficiency of 90% or less (the 94% are for sure optimistic) and 150W Pout the heatsinks looks a bit small. If you need half the power (75W) it most likely will do the job.
« Reply #2 on: May 09, 2015, 11:03:56 am »
Thanks, I will look for a beefier module then.
