Latching connectors are everywhere. Often they're tougher than the solder joints on the PCB, or the PCB itself.
Unless you quantify shock and vibration, your guess is better than mine as to whether you need something special or not. Do you think you need something that's literally bolted to PCB as well as soldered?
