Author Topic: Project idea, peltier/seebeck powered watch  (Read 2466 times)
Offline JJallingTopic starter
« on: March 17, 2015, 08:51:27 am »
I'm wondering why haven't anyone powered a semi-"smart watch" from a peltier/seebeck element? It's been a while, since I saw Daves video on energy harvesting, but as far as I remember, he got enough power to atleast power a small micro and one of Sharps memory displays.
I'm building a prototype to test things out, but has anyone some info they would like to share?
BR Jonas
Offline Torrentula
    • My blog
Re: Project idea, peltier/seebeck powered watch
« Reply #1 on: March 17, 2015, 09:55:57 am »
I'm not sure how much power you can really get out of the small surface area of a watch but I know there has been this project on Hackaday a while ago: http://hackaday.com/2013/12/02/energy-harvesting-peltier-ring/
He basically just lit up an LED with a peltier module and a DC-DC boost converter.
Offline eneuro
« Reply #2 on: March 17, 2015, 10:44:06 am »
Also working on similar watch, but I need power up to 3 leds (ok.they can be PWMed and supercapacitors used to charge them when display is deactivated I do not need them lighting all the time, just to check time when needed  8)
OK, we have 0.3V @ 20*C temp difference, but what about short circuit current-I mean power?
Need to watch again @Dave teardown.
The tiny Peltier plate he found generates about 0.3V with a temperature differential of about 20C — not bad...
The room has to be fairly cool for the LED to light, but [Sean] definitely proved his concept.
Probably it could better with much higher cooling area of watch holder or in swimming pool or while running or riding a bicycle.
Anyway, place such thing on two fingers much more difficult than at least 1inch2 watch surface with additional watch holder area looks like it can work  :-/O
12oV4dWZCAia7vXBzQzBF9wAt1U3JWZkpk
“Let the future tell the truth, and evaluate each one according to his work and accomplishments. The present is theirs; the future, for which I have really worked, is mine”  - Nikola Tesla
