While I did find multiple connectors that have what looks like an identical design from the datasheet drawing, each was rated for a different current (Within the same standard), so that seemed iffy!
ehhh, in many cases, these kinds of ratings don't really reflect the ultimate capabilities of the part itself. This becomes pretty clear in cases like this where all of these parts have the same basic geometry, same or similar materials, etc, but substantially different ratings. One manufacturer that claims a 10A rating probably isn't using some special contact alloy or some secret sauce fine detail on the shape of their contacts that makes their parts materially better than the manufacturer that only claims a 5A rating--if they were the brochures would crow about those things. More likely, the manufacturer with the higher rating chose to rate the part under different temperature or environmental or age conditions or something, or just chose to claim a rating that would be easier for them to get past a regulatory body. Or they may have been dealing with different regulations entirely , for example it's not unusual to see parts like this with different ratings under UL vs VDE standards--so the rating of the connector depends on the regulations that cover the device it's getting built into. If you were a really big customer you might even be able to go to that manufacturer with the 5A parts and, if you wave a big enough PO in front of their face, get them to recertify that part at a higher rating for you, possibly under a more narrow range of operating conditions.
Of course you would never design a product to exceed the manufacturer's stated and certified ratings, even if an apparently identical part from another manufacturer has a much higher rating than the one you pick. But it's useful to understand that behind those ratings isn't just a bunch of engineering about how 'how much current until it melts/catches fire' but a lot of 'how much current and under what environmental/usage conditions can we convince which regulatory body it will NEVER melt or catch fire'.
