I have included the LTSpice file .asc, so if you want to try it out go ahead.
I ran your circuit in qucs, Thanks.
In case anybody is inclined to use that circuit: ( and check following calculations before using)
For normal operation, switch on, when the 1 uF capacitor
does not fail:
The switch on voltage for example at -85 degrees applies about 300 Volt across the 100 Ohm.
The instanteous power in the resistor is about 1080 Watt, with an average of about 500 Watt over 150 microsecond.
I looked at two ratings of the 100 Ohm sacrificial resistor
1206 0.25Watt eg Yageo data sheet.
That resistor has a maximum rated voltage of 5 V, and its maximum overload Test voltage is 12.5 V.
So it would be exceeding its test voltage by 25 times during normal switch-on.
Maybe it would melt at first switch on.
2512 1 Watt to 3 Watt eg Multicomppro Pulse Withstanding Resistors series MCPW
That resistor has a single impulse rating tested by 50 pulses at 1 minute intervals for a resistance shift of 1%.
The rating for the 100 Ohm resistor is about 500 Watt for a pulse of 150 microsec (last graph in datasheet)
So it is on the limit, might survive in normal switch-ons.
The question is then, whether the sacrificial resistor of that high pulse rating would open early enough in the positive half cycle upon short in the 1 uF.
The 11V Zener CDZV11B has a rated current of 5 mA and absolute max of 100 mW , 9 mA.
If the 100 Ohm did not open before 5 millisec of the half cycle, that output voltage would increase to 20 Volt by the zener's impedance.
I have also seen zeners fail to Hi Z, if so the zener would not protect the electro or output voltage during the following half cycles.
The Microchip Doc AN954 refers to UL requiring input fuses and varistor.
I didn't find latest UL docs, anyway have no need to purchase them.
