Author Topic: center tap transformer project  (Read 869 times)
Offline grifftechTopic starter
    • youtube channel
« on: April 04, 2019, 02:57:25 pm »
the transformer is 24 volts with a 12 volt center tap, will this work?
Offline MarkF
Re: center tap transformer project
« Reply #1 on: April 04, 2019, 04:09:31 pm »
Yes.  But, I would add a few more components.  A couple protection diodes, output capacitor and a LED.
The LED provides a power 'ON' indication and more importantly a minimum load for the regulator.
If you care to have a PCB made, it might look like this.
« Last Edit: April 04, 2019, 04:21:44 pm by MarkF »
