Author Topic: Quadrupole in CRT - what's its purpose and how does it work?  (Read 567 times)
Offline gmayerTopic starter
Hi there,
I'm working on an oscilloscope from around the late 70s/early 80s with a Thomson CRT inside. This CRT uses quadrupoles which I've never heard of before. I understand that they are a part of the electron optics, but I couldn't find anything about how they work and affect the beam/deflection compared to a non-quadrupole tube. I can fix the scope without understanding that, but I'm just interested... Any information/hint is welcome :-) .
Cheers, Max
Offline Njk
  • Country: ru
Re: Quadrupole in CRT - what's its purpose and how does it work?
« Reply #1 on: May 12, 2024, 09:21:05 am »
First google hit:
Using magnetic quadrupoles in cathode‐ray tubes https://www.tandfonline.com/doi/pdf/10.1080/15980316.2002.9651898
« Reply #2 on: May 12, 2024, 09:53:26 am »
Thanks! That's a good starting point even thought it's probably not magnetic in my case.
P. S.
I swear I did some research before posting this. I can't believe I missed that!
Online David Hess
  • DavidH
« Reply #3 on: May 13, 2024, 06:08:38 am »
Tektronix published general details about quadrupole lenses:
https://w140.com/tekwiki/images/0/0f/Tek_forum_report_5.pdf
