Author Topic: which 3D compass + 3D inclinometer IC?  (Read 788 times)
Offline webgiorgioTopic starter
« on: September 09, 2018, 11:42:15 am »
which part number would you use for a 3 axis accelerometer + 3 axis magnetometer with i2c interface?
The module GY-511 is using a LSM303DLHC from ST, but on farnell/mouser it says that LSM303DLHC is out of production. (I can't use a module, I need to use the IC directly on my boards)
https://www.ebay.it/itm/GY-511-LSM303DLHC-3-Axis-e-compass-acceleration-sensor-modulo-w-Pin-Header/112577024152?hash=item1a361d1098:g:qmQAAOSwqDha~-Uz
I found a new part, LSM303AGRTR from ST, but the package LGA-12 is too small, 2x2x1 mm, Pin pitch is 0.5 mm. I am afraid of problems in the manufacturing. What do you think?
https://www.mouser.dk/ProductDetail/STMicroelectronics/LSM303AGRTR?qs=sGAEpiMZZMvzNxwKcL67%252blZFq4J3uRh8bxIk42XdBnY%3d
https://www.mouser.dk/datasheet/2/389/lsm303agr-954987.pdf
https://www.st.com/en/mems-and-sensors/e-compasses.html?querycriteria=productId=SC1449
« Last Edit: September 09, 2018, 12:12:41 pm by webgiorgio »
