Thank you all!
updating the schematic
@Terry, thank you also for the schematics. In you Clipboard_1.jpg schematic, C1, C2 and L1 form a filter, what is the function of R1 and how should I choose its value?
In the Clipboard_3.jpg schematic, to make best use of the CM choke on the output, shouldn't the ground connection be to the left of the CM choke (as per attached screenshot) or at least on both sides of the CM choke?
A MOSFET will limit your compliance voltage.
Do you mean my 2V across the voltage regulator that I control via the op-amp? If so that would be only for high current and quite high Rdson mosfets. So it sounds like you are referring to something else? Could you please explain a bit more.
You can get rid of the linear reg by using CV/CC switcher design. Just stick it CCmode.
Attached is a schematic for another project I'm working on. In that I have the the feedback pin controlled by the current through the load. I assume that classifies as CC, but I thought that solution will have higher noise than the schematic we are discussing for this project. But it sounds like that might not to be the case?
@David
The noise will be dominated by the noise of the bandgap reference inside the integrated regulator.
So am I correct in thinking that I could use a very low current regulator with even better PSRR than the current one and also a suitable large BJT bypass element and achieve the same or better performance?
@Benta,
that's correct, but that is acceptable because as mentioned in the OP an audible alarm informs the user to adjust the load accordingly.
Thank you all again!
