Author Topic: 3.3V LDO regulator circuit reverse polarity protection  (Read 2024 times)
Offline ilium007Topic starter
« on: August 13, 2021, 11:07:36 am »
Does this circuit look correct? I am building this power as a power supply for an ESP32 project and want to have both a USB-C power input and a 5VDC screw terminal input. I need reverse polarity protection on the screw terminal input.
Q1 is a logic level P-channel mosfet (https://datasheet.lcsc.com/lcsc/1810180217_Alpha-Omega-Semicon-AO3401A_C15127.pdf) with a low -2.5 Vgs and relatively low 80mΩ Rds.
Does this circuit look correct? Will this also give the USB-C input preference over the screw terminal input?
Online wraper
  • Country: lv
Re: 3.3V LDO regulator circuit reverse polarity protection
« Reply #1 on: August 13, 2021, 11:12:09 am »
Since you are using LDO and don't need full 5V, you can just use a Schottky diode from each input and not overcomplicate things.
EDIT: Your circuit is susceptible to ESD damage.
« Last Edit: August 13, 2021, 11:16:02 am by wraper »
The following users thanked this post: ilium007
« Reply #2 on: August 13, 2021, 11:15:09 am »
Will do, thanks. I was trying to be clever  :D
« Reply #3 on: August 13, 2021, 11:26:58 am »
This should work??
Online wraper
  • Country: lv
« Reply #4 on: August 13, 2021, 11:30:23 am »
Yes but you don't need 10k resistor unless you are using VBUS detection somewhere else.
« Reply #5 on: August 13, 2021, 11:38:15 am »
I missed that one. Thanks.
« Last Edit: August 13, 2021, 11:44:28 am by ilium007 »
Online Peabody
« Reply #6 on: August 13, 2021, 02:21:57 pm »
However, there is no preference in the diode circuit.  The power source with the highest voltage will power the load.  In your original circuit, if USB power is present, it will always power the load unless the screw terminal source is high enough to forward bias the mosfet body diode.  But if preference is important, you could still use the two-diode circuit, but make the screw terminal diode a regular rectifier diode.
