Author Topic: 3.5 mm 5-conductor TRRRS phone  (Read 1060 times)
Offline ebclrTopic starter
« on: June 08, 2019, 01:48:06 am »
What is the search name of the female of this 3.5 mm 5-conductor TRRRS phone connector
I need an smd connector for a project where can I find this?
Offline mariush
Re: 3.5 mm 5-conductor TRRRS phone
« Reply #1 on: June 08, 2019, 02:16:17 am »
You mean these? https://www.digikey.com/short/pmbfrt
If it's not for audio, you could probably get a better connector in the same general size (or maybe wider)... like for example something like mini/micro USB with a 5th pin (OTG)
The following users thanked this post: ebclr
