This looked like a fun project, so I thought I would build one of these frequency standards for myself. But I'm not very good at the dead bug style assembly shown in the thread. Plus, I find laying out circuit boards to be sort of therapeutic. I ordered up a few of the TCXOs and started a layout.
Never one to leave well enough alone, I thought I would add a small display so that you can see what frequency you have selected. If you are going to hook this to a frequency counter the display is kind of superfluous, but I don't even have a separate frequency counter yet, so the display helps.
Also, someone asked for a rotary encoder for input instead of a button. I thought that would be easier too so I added that as well. It makes selecting the frequency a little easier. The encoder also has a button, so I use that to switch between the table values and the numerical divisor. Since the encoder makes selecting the frequencies a little easier, I added a few more common (even) values to the table. And since in divisor mode spinning the knob all the way to 65000 is a pain, I made it so when you switch to divisor mode it jumps to whatever divisor the table mode was last pointing at.
A lot of times you will want to use this with a battery, but batteries have a habit of going dead, so I added a battery monitor that shows when the battery is getting low.
Finally, since there is a microcontroller in there anyway, I decided to make it remotely controllable as well. There's an FTDI port that you can drive from a USB converter to send commands to set frequency and change modes. The commands are all strings so you can drive it from any terminal emulator.
Here is a photo of the thing in operation,
a close up of the board,
and a screen shot of the output.
And since sharing is what the forum is all about, you can find all the design files, source files and documentation here:
https://github.com/uChip/FrequencyReference . I've shared out the board on OSH Park so you can purchase without resubmitting the design if you like. Details are on github.
Did I get carried away? Oh yeah, big time. But it was fun and I learned a couple of things. I totally blew the 3 USD budget, but it's still less than 22 USD total.
Thanks Paulie!
- Chip
