google image search for "RFID inductor" and you will see there is an immense variety of shapes and sizes of the antenna.
Using approximate sizes, the RFID stickers are circular, about 25mm diameter, with a 20mm coil diameter, and about 20-30 turns. That works out to about 90uH or so. The bigger square ones are harder to calculate. There is an empirical approximation for a square planar coil spiraling inward:
N is the number of turns, and D is the length of the largest (outer side) in mm. This works for squares, not rectangles. So lets assume a square of 5cm x 5cm , with 6 turns, then L would be about 850nH. So probably any high Q coil 1:1 coupling of about 1-100uH would be fine. You could probably put two small inductors side by side on the same board and they will couple, or you can actually use a transformer with primary and secondaries of a few uH. And, in fact, with such close coupling, you could probably get away with a very low inductance, perhaps just 100nH or so on a chip scale inductor.
