EEVblog® Electronics Community Forum
Welcome,
Guest
. Please
login
or
register
Did you miss your
activation email
1 Hour
1 Day
1 Week
1 Month
Forever
This topic
This board
Entire forum
Google
Bing
Home
Help
Search
About us
Links
Login
Register
Electronics
Projects, Designs, and Technical Stuff
Turn Normal Relay into Latching Relay
« previous
next »
Print
Search
Pages: [
1
Go Down
Author
Topic: Turn Normal Relay into Latching Relay (Read 2086 times)
Kedar264
Regular Contributor
Country:
Listen to Your Voice
on:
May 17, 2015, 05:25:29 pm »
Turn normal electric relay into latching relay only using neodymium magnet
Just open the relay and stick an neodymium magnet on to common terminal and that's all.....!
You can use this latch as memory, switch, etc.
This Modified relay doesn't need continues power ,input pulse is sufficient to latch the relay in one of the two states.
See the video
https://youtu.be/SxRl7rMPGRk
Logged
SeanB
Super Contributor
Country:
Re: Turn Normal Relay into Latching Relay
Reply #1 on:
May 17, 2015, 05:36:50 pm »
Nice mod, just will be a little vibration sensitive. If you use a larger relay ( plug in type) you might be able to do it and put the cover back on as well.
Logged
Print
Search
Pages: [
1
Go Up
« previous
next »
Electronics
Thanking...
EEVblog® Main Site
EEVblog® on Youtube
EEVblog® on Twitter
EEVblog® on Facebook
EEVblog® on Odysee
