Author Topic: 3478A FRAM modification  (Read 10304 times)
Offline wolfalexTopic starter
  • Country: at
    • My hobby electronics website
« on: August 16, 2016, 12:14:49 pm »
Hello,
Because I removed the battery inside my 3478A for internal shipping purposes I have already lost its calibration constants and this gave me the opportunity to implement an idea I had already
for a longer time. I really disliked the idea of buying a new lithium battery for my meter and to install it, especially because I know that there are much better options nowadays. This is when I decided to
modify my 3478A meter to use FRAM (ferreromagnetic RAM) instead of the original battery-backed up SRAM solution. I have never used FRAM before, and I thought this is the perfect occasion to learn and try out something new. I thought I add some information about this project here if somebody is interested :)
I do not know if somebody tried this before (or bothered to do so) or if my 3478A is now unique in this perspective :)
I added a page to my website showing more information about this modification. But I will also add some information here under this topic.
 http://wolfalex.bplaced.net/te/hp3478a/fram/hp3478a_fram.htm
Please keep the following in mind: Removing the battery, shorting the RAM supply voltage only for a split second or doing anything else shown on this page will result in lost RAM calibration constants. This will turn a still valueable and useful meter into a less valueable and useful one! Also handle the lithium battery contained in the 3478A with care. Never short the battery and be aware of the fire hazard. For disposal of batteries always follow safety guidlines and the industry/government rules/guidlines in your state.
I would be very happy if some of this information is useful or interesting for somebody. Just let me know what you think.
  • Country: at
Re: 3478A FRAM modification
« Reply #1 on: August 16, 2016, 12:19:00 pm »
Attachted is the glue-logic circuitry I needed to interface the used FRAM device FM18W08 to the 3478A internal databus. Also attached is the TL7705 reset generation circuitry which is added, because the original 3478A reset topoglogy stops working when the battery is removed.
I also added two pictures of the initial test which still uses the breadboard glue-logic circuitry :)
The following users thanked this post: jonovid, Dan N
  • Country: at
« Reply #2 on: August 16, 2016, 12:25:39 pm »
Attached are two scope pictures showing what the glue-logic is all about. The first picture shows the original unmodified SRAM multiple read cycle timing diagram. The second picture shows the same scenario, but this time at the FRAM pins. The FRAM needs a falling edge for every read/write cycle to internally latch the adress pin information, and therefore this falling edge has to be generated by the additional logic gates.
Offline David Hess
  • DavidH
« Reply #3 on: August 17, 2016, 09:44:29 pm »
The issue with CS needing to be toggled was discussed over on TekScopes@yahoogroups.com but the Tektronix guys lucked out; so far the oscilloscopes where the NVSRAM was replaced directly with FRAM worked fine because CS is toggled between accesses anyway.
Offline David Hess
  • DavidH
« Reply #4 on: August 19, 2016, 10:36:21 pm »
I was thinking about doing this as well, but after seeing all of the extra circuitry needed, maybe not.
I wonder if my 3458A can use non-volatile RAM chips [of some sort like FRAM or MRAM or ...] without all of the extra logic to toggle the `CS line...  It would be great to never have to worry about batteries again...
It will be able to use the EEPROM based NVSRAMs made by Cypress.  They just look like a normal asynchronous SRAM.
  • Country: at
« Reply #5 on: August 20, 2016, 09:33:29 am »
Sorry for my late response. I was following your responses on my phone more often, but I never found time to sit down on my computer to write a response. My initial plan was to just replace the SRAM with the FRAM device, and I thought there should be no problem with the /CS signal. Unfortunetly this was not the case, and so I added the additional logic. I just wanted to get it done and I had the logic parts laying around in my parts box, so it was just additional work :)
The last thing I have to do is to install the PCB somewhere in the meter. I hope I find a way to mount it without looking awful at the end and spoiling a otherwise nice looking meter.
@David: I was not aware that Cypress is building NVSRAM replacement parts based on EEPROM technology. Do you maybe have a part number? It would be interesting to look at it.
@DiligentMinds.com: I wanted to note that I have not spent any effort to optimize the glue-logic circuitry... it could be that someone finds a better circuitry to do the same :) For example from the XOR device I only use one out of the 4 gates. The only fully used device is the OR gate.
Offline David Hess
  • DavidH
« Reply #6 on: August 20, 2016, 09:54:07 pm »
Simtek was the original manufacturer but Cypress bought them some time ago.  The parts I used are marked SIMTEK STK16C88-WF45 (32k x 8b) but Cypress discontinued production of most of the through hole parts some time ago.  Some of the parts require a small external holdup capacitor.  At various times this technology has been refered to as SONOS, AutoStore, and most recently PowerStore.
Unfortunately the horrid Cypress web site prevents directly linking to most of its content so this is the best I can do.  The product selector link toward the top right will list the available parts:
http://www.cypress.com/products/nvsram-parallel
  • Country: at
« Reply #7 on: August 21, 2016, 09:05:25 pm »
Hello David,
 thank you very much for the Link. I looked at the datasheet of a part, very interesting. I was not even aware that this kind of device exists.
 Alexander
Offline David Hess
  • DavidH
« Reply #8 on: August 21, 2016, 11:04:13 pm »
Have you actually used this in a 3458A to replace the Cal-RAM?
No, I used these to replace the Dallas/Maxim DS1230AB NVSRAMs in my 2440.
They operate exactly like JEDEC standard asynchronous SRAMs because that is essentially what they are.  They are not a drop in replacement for U512 which is a 512 x 4 SRAM but they will not require extra logic.
  • Country: at
« Reply #9 on: August 28, 2016, 09:26:51 am »
I finally installed all components on a veroboard and connected everything again with the meter. I did not want to spend time drawing and ordering a nice PCB for the modification of only two meters. With the downside that my solution will never look professional and looks more like a big mess.
The last question was how to install the new FRAM PCB inside the meter. Unfortunetly with the size of the PCB (using veroboard and throughhole components) and the space restrictions in the meter I was not able to find a nicer solution. The PCB was put into a box to prevent shorts and then "installed" in the empty space inside the meter. Because I know I will never sell my meter this solution is good enough for me right now :) Functionality is my number one priority.
Offline bingo600
« Reply #10 on: August 28, 2016, 12:57:43 pm »
Nice solution.
But those leads are looonnnggg , could cause trouble on some systems. Where a DSxxxx is also used as "real Ram"
/Bingo
  • Country: at
« Reply #11 on: August 28, 2016, 03:39:00 pm »
Thanks. It seems until now I got away with the long leads, and I have not yet seen problems with it. I always get a Self Test OK message, and also the meter seems to work fine. But you are right, the possibility is there to cause problems. The original installed RAM device was called u5101L I believe.
Offline Tektron
  • Country: ru
« Reply #12 on: February 19, 2017, 08:16:47 pm »
wolfalex, thank you for helpful idea  :-+ !
3 weeks FRAM works in my HP3457A. No additional parts was used for memory (only wires and cutter  ;) ), just TL431+3 resistors for watchdog.
Offline bingo600
« Reply #13 on: February 19, 2017, 08:49:11 pm »
Schematic & writeup please  :-+ :-+
/Bingo
Offline TiN
  • Country: ua
    • xDevs.com
« Reply #14 on: February 20, 2017, 11:03:32 am »
In the works :) ETA This week, together with other interesting article  :-+.
Offline rastro
« Reply #15 on: February 20, 2017, 03:27:50 pm »
wolfalex,
I'm thinking about duplicating your design but I just can't source a box of Bio-Schoko-Beeren. ;D
Offline Tektron
  • Country: ru
« Reply #16 on: February 20, 2017, 09:02:11 pm »
rastro, if say seriously, you can remove 74HC14 and use still unused parts of 74HC86 instead inverters.
  • Country: at
« Reply #17 on: February 20, 2017, 09:46:10 pm »
   @Tektron: You are very welcome :) I can't wait to see your schematic and solution.
   @rastro: If everything fails I can supply you with a box of Bio-Schoko-Beeren :) When I have finished my second 3478A I will have the hard choice again which box to use  :-DD
   Maybe this time I will also try to keep the wires a little bit shorter.
Offline Tektron
  • Country: ru
« Reply #18 on: May 08, 2017, 03:59:55 pm »
/Bingo
Google translated. For professional translate we need wait, until this week will ended  :-//
Offline Miti
« Reply #19 on: February 26, 2023, 12:54:39 am »
I know some people hate necro posting but this is relevant and why start a new post when I want to talk exactly about this project?
I just found this project and I thought it is interesting so I made a quick schematic and board.
Is there any interest in this still? I still have one 3478A and I love it. I installed an easy to replace CR2030 battery but I want to try it nevertheless, particularly because I have the FRAM. I installed a socket today in preparation for the adapter board. The board may need some polishing and then I can post the Kicad project.
Cheers,
Miti
« Last Edit: February 26, 2023, 12:59:02 am by Miti »
Fear does not stop death, it stops life.
The following users thanked this post: lowimpedance, bingo600, coromonadalix, Tj138waterboy, pqass
Offline Miti
« Reply #20 on: May 25, 2023, 02:39:57 am »
And here it is, no more battery junk in my HP3478A meters
« Last Edit: May 25, 2023, 02:41:28 am by Miti »
The following users thanked this post: coromonadalix, wolfy007, ch_scr, pqass, Dan N
Offline Miti
« Reply #21 on: May 25, 2023, 12:26:02 pm »
And here are the final JLCPCB fab files.
The following users thanked this post: wkb, coromonadalix, ch_scr, pqass
Offline Miti
« Reply #22 on: May 29, 2023, 01:40:50 pm »
I found an issue with the supervisor chip trip voltage. Somewhere between the old version of 3478A with aluminum frame and the new version with steel frame, HP changed the diode CR500 from Schottky to silicon therefore the forward voltage drop is higher. My first install was on an old frame and it works well but on the new frame it holds the reset line indefinitely due to lower supply voltage on U512. I recommend you select an MCP101 with a lower trip voltage, use MCP101-450 or 315.
The following users thanked this post: wolfy007
Offline wakawaka
« Reply #23 on: March 09, 2024, 05:16:13 pm »
Hi Miti,
nice board! I've come across a unit with 3478A without even an SRAM chip :-DD and thought i'd take the opportunity to get rid of its battery as well. (no wonder it's uncalibrated)
Was wondering if you could make the kicad files available, it would help with modifying footprints for availability as JLCPB inhouse parts.
Best,
Waka
Offline Dan N
« Reply #24 on: March 20, 2024, 12:03:17 pm »
Nicely done mod.  I have a simple change for new builds that will increase endurance 8x.  Might be overkill, but the meter does constantly read the SRAM.
Because the FRAM is organized into 8 byte rows, a read of any byte causes a destructive read/write of all 8 bytes in the row.  Reading 8 consecutive bytes causes 8 destructive read/writes of the same row.
Putting only 1 value on each row eliminates this issue.  Simply use address lines A[10:3] and connect A[2:0] to gnd.
Offline Miti
« Reply #25 on: March 20, 2024, 03:33:24 pm »
Very interesting and valid point. But… See a screenshot from the FM16W08 data sheet.
2079920-0
Cheers,
Miti
Offline Dan N
« Reply #26 on: April 09, 2024, 08:05:38 pm »
Building on the good work of wolfalex and miti, I designed my own pcb for a couple of reasons:  I want it as small as possible and I want the overhang on the left side keeping the right side free for any future EPROM replacement/upgrade adapter.  I also included my row mod (2 posts above) to put only 1 value on each row.
First day installed and testing:  read/write cal data worked, with 5V rail at 5.069V, SRAM VCC was 4.796V, FRAM VCC is 4.833V so drawing less current through the diode.
For the glue logic I used multi-function logic (74LVC1G57) to get the exact functions I wanted and squeeze everything between the DIP pins.  May have slightly less logic-H margin than an "official" TTL compatible input, but works for now and will see if further testing shows any issues.
As wolfalex mentions on his website, I installed a resistor in place of the battery (see pic) to keep a comparator input from floating.
« Last Edit: April 09, 2024, 11:26:22 pm by Dan N »
The following users thanked this post: Miti, edavid
Offline Miti
« Reply #27 on: April 11, 2024, 02:56:35 pm »
Thanks Dan, looks good!
Only one concern. On the Reset line, you basically short circuit a 1uF capacitor, potentially charged to 5V. MCP120 data sheet doesn’t seem to specify a maximum output current but it could give a significant spike.
That’s the reason I used a transistor that can take few hundreds mA. Still not ideal, I should have used a current limiting resistor series.
Cheers,
Miti
Offline Dan N
« Reply #28 on: April 11, 2024, 08:15:44 pm »
I was also concerned about the current sink limit.  Top priority is the ability to pull the reset down fast enough to prevent spurious writes on power-down, and even that is only an issue if the cal switch is enabled.
I looked at the current sink chart for the LM339 in the original reset circuit and it maxes out at 16mA before dropping out of saturation and then the voltage rapidly climbs past 1V.  The MCP120 chart shows it's below 600mV at 16mA so the MCP120 should pull reset down faster than the LM339.
I'm less certain of this calculation but peak current shouldn't be an issue.  From the same MCP120 output chart the equivalent resistance is 30-40ohm (increases at higher current).  Discharge time should be <150uS.
EDIT:  I scoped CE2 (reset) and it drops to 2v @ 55uS, 1V @ 80uS, 0V @ 146uS.  My adapter is soldered in so I have no way to compare with the old LM339 reset.
« Last Edit: April 12, 2024, 01:06:20 am by Dan N »
Offline Dan N
« Reply #29 on: April 12, 2024, 03:47:28 pm »
All versions of the FRAM mod add a new reset circuit onto the FRAM VCC supply which comes through a diode from the regulated +5V rail while the original was directly on the unregulated 5V (really 13V).  I assume the regulated rail has more bulk capacitance and drops slower than the unregulated rail, and the diode can keep the FRAM VCC higher than the cpu +5V rail, so the original reset may trigger sooner at power-down.
I wanted to confirm that the new reset circuit shuts down the cpu before its supply falls below 4.5V.  The attached scope screenshot shows that it does.  Yellow is CE2 (reset), purple is ALE (cpu activity), blue is the cpu +5V rail.  The FRAM VCC drops enough for the MCP120 supervisor to trigger reset while the cpu +5v rail is at 4.5V and 89uS (35 instructions) later the cpu halts.  The +5V rail doesn't drop any measurable amount on this trace.
So all versions of this mod should be good.  :-+
« Last Edit: April 12, 2024, 07:53:01 pm by Dan N »
