Author Topic: Multiple MOSFETs in a single package?  (Read 8900 times)
Offline MacAttakTopic starter
« on: June 14, 2013, 02:03:58 am »
I was looking at this application note about bi-directional level shifting: http://ics.nxp.com/support/documents/interface/pdf/an97055.pdf
The design calls for discrete MOSFETs (N enh) plus some passive resistors. For a simple shifting implementation, it requires two transistors per signal line. In this case, I would like to perform automatic level shifting for a lot of signals - roughly 80 to 90. Going with discrete transistor packages, there is no way I could hope to fit that many (plus three resistors for each signal) on a PCB of reasonable size. And while buying a few chips won't break the bank, when you need ~200 for a single board it adds up. Example transistor mentioned in the app note: http://www.digikey.com/product-detail/en/BSN20,215/568-1658-1-ND/763485
I've tried looking for multi-FET array packages for this application, but haven't turned up anything. Surely someone must offer quad FETs in a single chip (or 16, or even 8 )?
I know that normally, you would only perform level-shifting on the few signals you care about, but in this case I want to have a general-purpose level shifting adapter that lets me plug average 5v Arduino-style shields into my FPGA board that only wants 3v3 (and I don't think it is 5v tolerant, nor would I expect the 5v shields to be 3v3 tolerant).
All of the purpose-made level-shifting chips I have seen that can handle multiple signals are useless for this purpose, because they are either unidirectional or they require another external signal to control the direction of all shifted lines.
duskglow
  • Guest
Re: Multiple MOSFETs in a single package?
« Reply #1 on: June 14, 2013, 02:59:16 am »
I have some dual mosfets in a SOP-8 package.  Pretty compact.  CEM4953 (I believe).  I bought 50 for around $16.
« Last Edit: June 14, 2013, 03:01:03 am by duskglow »
Offline c4757p
  • adieu
« Reply #2 on: June 14, 2013, 03:01:01 am »
Two MOSFETs per SOIC-8 is huge if you want to level shift 90 signals with them!
duskglow
  • Guest
« Reply #3 on: June 14, 2013, 03:01:30 am »
It was SOP-8.  My mistake.  They're pretty little guys.
Offline croberts
« Reply #4 on: June 14, 2013, 03:06:25 am »
DigiKey does have MOSFET arrays in Product Index --> Discrete --> FETs - Arrays but only 4 per package max as matched pairs.
Offline free_electron
    • SiliconValleyGarage
« Reply #5 on: June 14, 2013, 03:19:11 am »
there are chips that have that circuit avaialble in ulti lanes ( up to 8 i believe ) maxim and linear technologies have em. max 37xx series i believe.  made for i2c and spi buses
st has one in flipchip ( really tiny )
Offline Rufus
« Reply #6 on: June 14, 2013, 03:33:50 am »
Analog do some octal bus switch/passive level translators. ADG3300 is a 5v capable example.
