Author Topic: PCB design and schematic for a half bridge power amplifier.  (Read 880 times)
Offline thambiTeaInnumVaralaTopic starter
« on: March 17, 2019, 08:30:04 am »
I am making a half bridge power amplifier that operates at 24 V.
The bridge has to supply around 3A current to an inductive load (10mH)
The bridge will be controlled using 20kHz PWM from a microcontroller.
I have put a ACS712 current sensor in the load path to give feedaback to the microcontroller.
There is a IRF9Z24 P FET at the top and a IRFZ44 N FET at the bottom.
Both are driven by a single MC34125 Gate driver IC, which has a 12 V power supply.
The gate driver is connected to the microcontroller through a HCPL optocoupler.
I have maintained 80mil track width for the 3A paths, from a online track width calculator.
I have put necessary decoupling capacitors for the optocoupler and the gate driver  ic.
There are 2 copper filled ground planes on top layer and bottom layer that I have not shown in the pcb schematic for visibility.
I have made a schematic and circuit diagram that i have linked here.
Pl suggest any modifications or pointers that will improve the circuit.
Thanks.
BS
Offline diyaudio
Re: PCB design and schematic for a half bridge power amplifier.
« Reply #1 on: March 17, 2019, 01:45:05 pm »
So many things needs attention. I recommend you post a working breadboard version capped at 1A, verify you can actually achieve "amplifying a signal"
« Reply #2 on: March 18, 2019, 02:31:19 am »
I will get a version working on prototype board and will post it.
I will limit the current to 1A with pwm duty cycle control.
Thanks.
