Hi all, so annoyingly the post I had written up got nuked going through my history, I've been trying to find the chip that had looked good for the buck/boost side, but no joy so far.
Basically, I'm looking at a small project to rid myself of D cell batteries, and I want to replace two pairs of them with a lipo pack in a drop in case, so I don't have to modify the device in any way. Chances are it won't run as long but it will be massively more convenient.
So, I need two 3v outputs, fed from a lipo battery, that's fairly easy with a buck/boost converter chip, however, I need the two outputs to be isolated, as there's a tap off of the middle of the two sets of batteries, and connecting a common ground to the output of a converterwould be a dead short, no bueno.
So, I was looking for a magic chip that handles buck/boost and isolation duty to provide a 3v output from 2.7-4.2v in, but I haven't had any luck, so my next best guess is using a buck/boost converter to obtain the steady 3v (or possibly higher), and then run that through another chip which isolates the output.
I am hoping to avoid linear regulators to make this more efficient since I'll be going from the substantial rating of four d cells down to only 4000mah of lipo. I only need around 36ma on the output overall, so it's nothing particularly intensive.
It does seem that I may need to go for a 3.1 or 2.9v output since straight 3v isn't available for the things I'm currently looking at.
Unfortunately at the tail end of a long day so definitely struggling to find what I had before and probably missing something output. I had been hoping to figure this out solo but loosing my place didn't help. My 3d printing now layer shifting like crazy for no reason is really starting to piss me off too.
