I'm clueless about analog computers but I can make a general suggestion: go to Mouser and/or Digikey (or other distributor) websites and use the filters to narrow down the options under the op-amp category. Alternatively just browse for op-amps on the manufacturer's (Texas Instruments, Linear Technology, Analog devices, etc.) and use their parts filters to find any suitable candidates. Then check if any of the distributors most convenient for you have those parts in stock.
I guess I'm just not smart enough about op amps to know which questions to ask or which parameters to filter. I suppose if the word 'Precision' shows up, that is a good thing but the range of op amps seems overwhelming.
My primary application is, of course, integrators. Nice, linear and with little to no leakage. Leakage messes up long running simulations, eg generating a circle with two integrators and an inverter will show a declining radius over time. Well, sure, energy is lost to the environment and not replenished so, yes, there will be leakage at the system level.
I found an old article (50 years old!) written by one of the founders of Analog Devices that discusses in great detail the problems with integrators. Maybe when I digest it, things will become more clear (or not...).
ftp://ftp.analog.com/pub/cftl/ADI%20Classics/Ray%20Stata%20Articles-1960s/Operational-Integrators.pdfAnalog computing is a kick! I have built up some modules to use with LTSpice and MatLab includes everything necessary but it's just not the same as patching up a circuit to analyze damped harmonic motion or just a falling object. I really wish we had had analog computers when I was studying differential equations. It would have made the subject more 'visual'. Somehow, an exponential decaying envelope over some sin() terms just doesn't mean as much as a trace on a scope.
