Hi All,
I am working on 4 Layer Board Having some High Voltage Sections(125 Volts), and a bunch of other stuff like DAC, MCU. Would love to have some opinions, corrections, suggestions for the layout.
Some routing and Ground Connections are still in progress, but most routing is done.
One on the Top LEFT is HV Switching Type Boost Convertor and Centre one is an OPAMP whose output can go up to 100V which is connected to SMA
Thanks in Advance.
