Author Topic: 4-quadrant DC/DC converter - advantage and disadvantage  (Read 3642 times)
Offline MehranTopic starter
  • Country: ar
« on: May 23, 2020, 04:05:09 pm »
I have been given a multi-part question to answer. Answered everything but stuck on the last part, which asked for a 4-quadrant DC/DC converter - advantage and disadvantage but can't use complexity and
cost as a disadvantage. I cant use the lecture sides since... don't want to say any bad... but not up to standard for an EE course. Google is like  :horse: plenty of advantages but not being able to say cost or complexity for a disadvantage has really cut me off at the knees.
Any good technical reasons why a 4-quadrant DC/DC converter should not be used over a 2-quadrant? Or a drawback...or anything other than cost or complexity?
Any ideas? thanks
Offline Siwastaja
Re: 4-quadrant DC/DC converter - advantage and disadvantage
« Reply #1 on: May 23, 2020, 05:34:40 pm »
The question seems, IMHO, so strange that just making sure, do you know what 4-quadrant operation means? Let's start there.
Obviously, if you require 4-quadrant operation, then it's indeed an "advantage" being able to do what you need to do. If you don't require it, then there are the obvious disadvantages of complexity and cost you already listed.
The following users thanked this post: Mehran
Offline Benta
« Reply #2 on: May 23, 2020, 05:38:16 pm »
I'm also stumped.
OP, could it be that you mean full-bridge vs. half-bridge?
Offline Picuino
    • Picuino web
« Reply #3 on: May 23, 2020, 08:10:03 pm »
1 quadrant means positive voltage and positive current. You feed a motor only in one direction and only for accelerate, not to slow it down.
You can do this with one transistor.
2 quadrant means positive voltage and positive or negative current. The motor runs only in one direction but in this case you can accelerate and decelerate it. In this case you need 2 transistors (half bridge) and has one disaventage: the deceleration energy of the motor pushes up the input voltage so, to avoid this, one mechanism is necessary to consume this electric energy.
4 quadrant is the same that 2 quadrant with the capacity of moving the motor in both directions. In this case you need 4 transistors (full bridge)
« Last Edit: May 23, 2020, 08:19:10 pm by Picuino »
Offline Benta
« Reply #4 on: May 23, 2020, 08:31:34 pm »
From the Department of the Obvious.   :palm:
There's a heck of a lot of difference between a DC/DC converter and a motor controller.
We're still waiting for the OP's reply. I have a feeling it's a language issue.
Offline Picuino
    • Picuino web
« Reply #5 on: May 23, 2020, 09:14:51 pm »
4 quadrant has the disadvantage of having a higher voltage drop and greater dissipation because the current has to pass through two transistors.
The advantage is that you can rotate the motor in two directions.
Offline Picuino
    • Picuino web
« Reply #6 on: May 23, 2020, 09:26:01 pm »
Simple question, simple answer  :)
No, they are the same thing, and it seemed to me that Mehran was talking about motor controllers.
Offline Benta
« Reply #7 on: May 23, 2020, 09:29:51 pm »
It's a trick question.
Back when I studied EE, I had a professor who loved doing that as well.
The so-called "2-quadrant" controller will only work in one direction. The lower transistor can be used for braking, that's all.
The full bridge will let the motor operate in both directions, and will provide braking in both directions as well.
Offline Picuino
    • Picuino web
« Reply #8 on: May 23, 2020, 09:44:42 pm »
"Braking" is performed with both transistors (Low and High side) transferring energy from the motor (acting as dynamo) to input voltage source (like a boost converter).
When that input source does not accept to absorb energy, it has to be dissipated in resistors. Is the case of big brake resistors placed at the top of the trains.  http://www.resistorguide.com/braking-resistor/
The "hard braking" made by short-circuiting the motor with the low side transistor can burn out transistor and/or the motor itself because the large amount of kinetic energy that is converted into heat.
« Last Edit: May 23, 2020, 09:50:31 pm by Picuino »
Offline Benta
« Reply #9 on: May 23, 2020, 09:50:46 pm »
"Braking" is performed with both transistors (Low and High side) transferring energy from motor to input voltage source.
When that input source does not accept to absorb energy, it has to be dissipated in resistors placed for that. Is the case of big brake resistors placed at the top of the trains.
Who said anything about "hard braking"? PWM is also an option. And now you're talking about "resistors placed on top of trains"?
This is no longer normal.
The fact is, that the so-called "2-quadrant" stage will only power the motor in one direction.
'Nuff said.
Offline ch_scr
« Reply #10 on: May 23, 2020, 10:41:32 pm »
If you only need one direction, the 4 quadrant has the downside of having more losses, does'nt it?
Offline Picuino
    • Picuino web
« Reply #11 on: May 24, 2020, 09:02:39 am »
I need a resistor to dissipate the braking energy. Why do you say the braking resistors are not normal?
Yes, twice as many losses because the current goes through two transistors instead of one.
Offline Jay_Diddy_B
« Reply #12 on: May 24, 2020, 06:09:35 pm »
There are other examples;
Low voltage UPS.
You can have a synchronous buck batter charger, working as a synchronous boost in the back-up mode.
This is two quadrant positive voltage, positive and negative current.
TEC controller
This is two quadrant, positive voltage, positive current and negative voltage, negative current.
A class D amplifier is four quadrant.
A 4 quadrant  power supply must be fed by a two quadrant power supply, that is one that can absorb power.
In two of the quadrants power is flowing from the load back to the source.
Regards,
Jay_Diddy_B
