In order to correct my biggest nit pick about the usupply (no negative sense line / no correction) i set myself to make a 4 wire sense correction amplifier,
first i began with only a standard error amplifier and a differential amplifier amplifying the difference, but noticed there was one massive flaw to this design, should one of your sense lines become disconnected your output shoots off to maximum which generally is very, very bad for whatever you are powering,
so i added a second differential amplifier to measure the difference between what was already being measured and what was being put out, in other words how much correction was being applied, that was then fed into an op amp acting as a comparator, which then drives a mosfet and clamps the original error amplifier into a simple buffer should it become greater than the programmed limit, and act in the linear region to stabilise
the 2.2V input is a voltage i am aiming for as my lowest voltage and most likely to cause me grief, mainly as most op amp common mode ranges up to vss-0.9 to vss-1V or much worse (part of the reasoning to keep the signal levels low)
so i offer up my design for all the scrutiny it is worth, and am happy to take on any constructive criticism, mainly i would like to know if there are any major issues with this design i have overlooked, or if there are any very simple improvements you can think of,
in my own mind i hold doubt about my differential gain resistors, but would like a second opinion
and if you want to play with it, here it is albeit a little messy
http://tinyurl.com/9mrjbls (falstads)
