Hi all,
First time posting – I'm fresh into electronics, and I've hit some snags whilst copying one of the preamp channels from a Sunn Beta Lead schematic. (I've highlighted reference points for my questions.)
There's a number of questions I'm afraid, not so familiar with forum etiquette!
(Highlighted schematic attached is original one, and the other is my copy done in KiCad.)
Pink staggered line is one of the 2 channels for the preamp section, which is what I'm copying.
Question 01: There are capacitors that don't have uf/nf/pf multipliers, some are just ".0022" (e.g. C105 (in left green box)). Am I right in thinking this is ".0022F"?
The 4 caps in the green boxes have been a nightmare to find, so by recommendation from a friend I've swapped the following caps to (->) different values:
- C105 .0022 -> 2.2pf
- C106 .047pf -> 1pf
- C140 .005 -> 5nf
- C143 .027 -> 27nf
Question 02: How are these alternatives worked out? What
super basic knowledge have I missed out on?
Question 03: There's an op amp (IC110) marked in red and blue that's shared between the 2 channels. For the one channel version that I'm making, should I still connect pin 8 to +15V and pin 3 to GND? If so, why? If not, why not?
Question 04: The op amp (IC109) before the previously mentioned one (IC110) doesn't have any reference to pins 4 & 8 being connected to the usual +/-15V, though the IC datasheet shows that those pins are reserved for +/-V. Should I connect these pins to the usual +/-15V or should I leave 'em disconnected (as the schematic seems to suggest
See below for my copy of the schematic (omitting the FETs (e.g. Q103)).
Thank you all in advance!
