Author Topic: 5 pin connector, safe, low cost 300V (one pair 240Vac, one pair 120Vac, < 10A  (Read 1094 times)
Offline JesterTopic starter
Any suggestions for a 4 or 5 pin plug/receptacle:
This is for a control cable between a control panel and a machine. Indoor, no requirement for water or fluids etc.
Safe
Low cost
Some sort of lock so it won't fallout if vertical mounted
300V (one pair 240Vac, one pair 120Vac,  5A minimum
Chassis mount and free hanging for cable
« Last Edit: January 02, 2024, 01:22:33 am by Jester »
Offline themadhippy
blue 5 pin  ceeform (IEC 60309) ? Although depending on your supplier it might fail the cheap option
Online dobsonr741
Offline langwadt
HDC-HA ?
Offline T3sl4co1l
    • Seven Transistor Labs
Any 0.156" rectangular header will do the job e.g. Molex KK or SPOX.  Friction ramp holds in place.  A zillion others (clones and otherwise) by every manufacturer.
For easier wiring, Eurostyle pluggable terminal strips.
Seven Transistor Labs, LLC
Offline ArdWar
  • Country: sc
Please do not use standard connector for non-standard usage. Especially when 240Vac and 16A are potentially involved.
Offline Jeroen3
  • Embedded Engineer
    • jeroen3.nl
You can go with the usual standard round cannon connector. But wiring those is a hassle.
If space constraints allow perhaps looking into Harting HAN 4 A or something similar.
If you stayed in ELV range you could have used something from Neutrik, those are high quality.
Or something less robust you can take locking Phoenix MSTB and put the KGG housing around it.
Offline Terry Bites
Pluggable terminals. Phoenix Contact, TE, Wurth etc... Plenty of generic and knock off versions on Ali, ebay etc.
They are rugged and field rewirable. I love em.
