Welcome,
Guest
. Please
login
or
register
Did you miss your
activation email
1 Hour
1 Day
1 Week
1 Month
Forever
This topic
This board
Entire forum
Google
Bing
Home
Help
Search
About us
Links
Login
Register
Electronics
Projects, Designs, and Technical Stuff
BNC connector mounting
« previous
next »
Print
Search
Pages: [
1
Go Down
Author
Topic: BNC connector mounting (Read 1936 times)
Vgkid
Super Contributor
Country:
on:
April 28, 2015, 04:23:50 am »
How would one mount a female BNC pannel mount connector, without making the D shaped holes. Could I just titen down the nut all the way.
Logged
Richard Crowley
Super Contributor
Country:
KJ7YLK
Re: BNC connector mounting
Reply #1 on:
April 28, 2015, 04:49:58 am »
Sure, people do it all the time. But you wouldn't have much protection against rotation.
Logged
kjs
Regular Contributor
Country:
Reply #2 on:
April 28, 2015, 04:52:12 am »
the D-shape prevents that the socket is loosening over time (and it will otherwise). I usually drill the hole pretty tight and put a very small amount of Epoxy glue into the D as a makeshift solution when I don't have a way to get them done properly. A pain to get the jack out again but better than always re-tightening the nut and a spinning jack.
Last Edit: April 28, 2015, 04:55:47 am by kjs
Logged
Vgkid
Super Contributor
Country:
Reply #3 on:
April 28, 2015, 12:31:16 pm »
I think i will use epoxy, and titen the nut down tight. These will be on the back of a piece of equipment,no frequent removals.
Logged
smjcuk
Frequent Contributor
Country:
Reply #4 on:
April 28, 2015, 12:45:00 pm »
I buy the ones with flanges on rather than relying on the D. You have to drill 5 holes but it's easier to work with and they stay put.
Logged
TimFox
Super Contributor
Country:
Retired, now restoring antique test equipment
Reply #5 on:
April 28, 2015, 09:20:13 pm »
If you drill a clean 3/8" hole, you can hit the panel just outside of the hole with a center punch and pick up some anti-rotation effect.
Logged
babysitter
Country:
pushing silicon at work
Reply #6 on:
April 29, 2015, 05:22:01 am »
enclosure made of thermoplastic? Drill a tight fitting hole and use a relatively cool soldering iron to press some enclosure material back into the hole.
Logged
I'm not a feature, I'm a bug! ARC DG3HDA
Print
Search
Pages: [
1
Go Up
« previous
next »
Electronics
Thanking...
EEVblog Main Site
EEVblog on Youtube
EEVblog on Twitter
EEVblog on Facebook
EEVblog on Odysee
